Djurhamn
18 -
Djurhamn/Stockholm
Autos und motorräder
Hello i have 3st smart fortwo and everone has this problem if i park it outside wintertimes its a big problem to move it. I think its the brakes in the back even if it the handbrake is loose from the beginning. I dont have this problem on my other cars Renault and Citroen. /Björn Stockholm
Hi friends do someone now why the anlasser go slowly whit a strong battery the car is a 45 ps , the car has runn 145000km and also wich part of the motor that is make ölverlust ca 1 liter under 2000km is it the zylinderkopf only or also the kolbenringe i have change oil offen whit high fullsyntet oil 5w-40
Sorry i has wrote wrong its 10mm toe in and more bad on the inside ? It should normaly was more bad on the outside ? And the car has 145/65R15 :-?
Hi thanks for your help whit the answer ! No i has not make any changed things in the front its like original. Best regards Björn
I have a -99 the adjust of the frontwheels is maybe not correkt because the tires is more bad on the inside than outside but when i meassure it its more toeout than it should, strange !!!! What is this is it camber or caster problems the car is also instabil when its little bad motorways. I hope someone can give me a tip Thanks Björn Stockholm
I have a Pure 45ps 1999 do anyone nows the km between the change of this 6 sparkplugs
Do someone now the Smart orginal spare part number for the opening handle left side for a Smart for two -99 or whats normal to change when its not going to open from outside only work on inside
Thank you for all your tips Björn
Hello freunde ! do someone knows how i get some more power in my pure whit only 45 ps and is it possible to get faster change on the gears Björn Stockholm
Thanks for your answer ! but if you put brietfelgen on a BMW for exempel its more nervous on bad motorways its not so stabil and if you put on the economic 185/65r15 again its going lik a train Regards Björn
Thanks for your tip
I have a Fourtwo from -99 its not so stabil on motorways ! anyone whit a tip or is the car like this ?
My Smart from -99 its not so easy to drive on motorways is nervous ! should it be like that its not a big car or should it help to adjust the front wheels setting ?
i it possible to put in a ölschraube in the oilreservoar to easeyer change oil and get out all used oil ?
Thanks for your tip but do you now how to give it power to the batteri from the backdoor
