dongfang
    6
  1. Mobile crusher is specialized in crushing, screening, conveying and ore dressing, which has several features such as small footprint, strong flexibility and mobility. It is suitable for construction waste disposal, construction waste crushing and mining. construction waste crusher is the best equipment for construction waste disposal! construction waste crusher is a new kind of rock crushing machine, which can eliminate barriers caused by crushing site and the environment to offer customers low-cost and effective operating hardware. It is able to conduct on-site crushing of materials, and move with the mining surface of raw materials, thereby significantly reduce the transportation costs of materials. SBM Machinery has designed the mobile crushing and screening equipment on the basis of the original technology, which can adapt to a variety of situations, so as to create more business opportunities and reduce production costs for customers. China is still fast in urbanization; as a result, the issues of transportation and environment in urban areas are becoming hotter and hotter. Therefore, the impact of Chinese investment in infrastructure on the downstream industry will be changed from the total amount to the structure factors in the future. With the development of SBM Heavy Machinery mobile crushing station, crushing equipment has been used in the new field of dry mortar, construction waste disposal and other new areas. Therefore, the market space of construction waste disposal has been greatly expanded. From the perspective of environmental protection and sustainable development, mobile crushing station has created a new market of machinery industry. SBM Heavy Machinery has put forward a set of mobile crushing station to make it convenient and efficient for construction waste crushing on the basis of integrated units. Iron will be removed out of the selected materials by removing equipment. By rough crushing, medium crushing, or fine crushing processing, materials without iron are processed into recycling aggregates of certain sizes. Finally, these aggregates are applied to the roadbed stone, unburned brick, cement admixtures and many other products. The advent of mobile crushing station can not only deal with the urban construction waste disposal problems, but also promote the development of urban construction waste disposal onto the way of environmentally friendly, to achieve effective recycling.
  2. The rapid development of urban construction economy, construction waste pollution gradually surfaced in the future direction of urban development, green is an inevitable trend. Mobile crushing plant is an emerging product in the construction waste crusher industry that can recycle construction waste. This mobile crushing station opens the new era of application of construction waste to lead the development of aggregate industry, to tell you about the application prospects of mobile stations and construction waste aggregates. Mobile crushing station to reduce the environmental pollution of construction waste, optimizing renewable resources, for the construction of waste disposal, and the development of building materials to provide a new way. In the future trend of development, high-tech, green information must be the operation of the mining machinery industry goals. The construction waste crusher developed by our company has solved the bottleneck problem of the urbanization process, opened up a new mode of green building in cities and towns and led a new era of application of recycled aggregate for environmental protection in the construction industry. With the speeding up of construction, building aggregate has become an indispensable raw material to be purchased by all builders, but there is a shortage in natural sand market. This time instead of natural sand for the construction of the best raw materials, that is, recycled aggregate construction waste. Therefore, the application of construction waste recycling aggregate wide range of applications. The mobile crushing plant is the key to open construction waste crusher applications. Mobile crushing plant professional broken construction waste, reduce environmental pollution caused by garbage, so that building waste is reasonable and recycling, so that renewable resources can be meticulous and optimized. In short, the development and production of WITTMANN Mobile Station has not only opened up a new mode of production for the construction waste disposal industry, but also a good thing for the benefit of the country and the people.
  3. As a kind of common grinding equipment, the high-efficiency grinding mill, with the advanced machine structure at home and abroad, has been updated on the basis of the property of other common grinding mills. Compared with the ball mill, the grinding mill has higher efficiency, lower power consumption, less floor space, and less one-off investment. Although the grinding rolls and the grinding ring of the grinding mill have been worn to a certain degree, the quality and the fineness of its final product are not affected due to the centrifugal force of the machine. Its quick-wear parts should not be replaced very frequently for the long service life of the grinding rolls and the grinding ring. With the cyclone separator and the blower, the ultrafine mill is of less dust. The ultrafine mill mainly consists of the main engine, analyzer, blower, cyclone separator, and the air hose. In many industries like mining, the ultrafine mill is widely used to make ultra fine powder from many kinds of materials, such as soapstone, marble, limestone, etc. The range of the particle size of its final product is 80-425 mesh even the particle size of some material ground by it can be 600 mesh. In the operation of the ultrafine mill, after the material is fed into the machine from the side hopper of the machine, the grinding rolls hanging on the star rack rotate around the vertical shaft and press the grinding ring, which can make the material be ground.
  4. As a kind of common grinding equipment, the high-efficiency grinding mill, with the advanced machine structure at home and abroad, has been updated on the basis of the property of other common grinding mills. Compared with the ball mill, the grinding mill has higher efficiency, lower power consumption, less floor space, and less one-off investment. Although the grinding rolls and the grinding ring of the grinding mill have been worn to a certain degree, the quality and the fineness of its final product are not affected due to the centrifugal force of the machine. Its quick-wear parts should not be replaced very frequently for the long service life of the grinding rolls and the grinding ring. With the cyclone separator and the blower, the ultrafine mill is of less dust. The ultrafine mill mainly consists of the main engine, analyzer, blower, cyclone separator, and the air hose. In many industries like mining, the ultrafine mill is widely used to make ultra fine powder from many kinds of materials, such as soapstone, marble, limestone, etc. The range of the particle size of its final product is 80-425 mesh even the particle size of some material ground by it can be 600 mesh. In the operation of the ultrafine mill, after the material is fed into the machine from the side hopper of the machine, the grinding rolls hanging on the star rack rotate around the vertical shaft and press the grinding ring, which can make the material be ground.
  5. The higher demand for energy power has been entered into one peak period with the economical development, and the realization of the western development, mineral exploration, energy saving, emission reduction and the other strategies brings along the popularity of construction waste crusher, which also boosts the rapid development expansion of mining equipment market. Coal mining is the most important energy power of our nation, and to establish the large-scale open-pit coal mining is one important development tendency of our construction on energy power. The popularity of mining construction will undoubtedly provide the excellent market opportunities for mining equipment manufacturers with the expansion of mining construction boosted and enhanced by our nation. Our national mining equipment manufacturers, such as crusher manufacturers will try their best to occupy one important part of this construction waste crusher. At this right minute, mining machinery will undoubtedly become the emphasis point with the strong support of our national policies and the combination of industrial structure of our mining enterprises, and large scale, high efficiency, energy saving mining equipment will be the most popularity in those mining exploration enterprises. SBM mining machinery mainly produces crusher, vibrating feeder, vibrating screen and the other mining equipment by introducing the overseas advanced technology, researching and developing the new products according to the concrete requirement of customers in order to provide the strong help for the whole mining construction.
  6. Both Ball mill and ultrafine mill belong to the grinding machine, but there are big differences between them. Now we will explain the characteristics and differences of the two devices to provide some help for you when purchasing the equipment. 1. Different Equipment Structure The ball mill is composed of the feeding part, discharging part, rotary part, transmission part (reducer, small transmission gear, electric motor, electric control) and so on. B all mill is mostly horizontal. But ultrafine mill is vertical structure, which is composed of host, analyzer, fan, finished cyclone separator, micro-powder cyclone separator and duct composition. Ball Mill 2. Different Grinding Fineness The feeding size of ultrafine Mill is generally 15 to 20mm, and the granularity of finished products is usually 0.044 to 0.125mm. ore milling equipment is mainly used for grinding a variety of stone, ores, building materials, chemical materials, such as graphite, talc, kaolinite, limestone and other materials, etc. It's suitable for engineering and projects with high requirements for some material fineness. ultrafine Mill Ball mill is widely used in black and non-ferrous metals processing, fertilizer processing, refractory materials processing and manufacturing, and so on. It can grind the material in dry type and wet type. The finished product fineness is up to 425mesh, which is commonly used for material grinding of mineral processing production line. 3. Different Granularity of Finished Products The ball mill has fast discharging speed, so its finished grain size is relatively coarse. Its grinding granularity is 0.3 to 0.2mm or 0.074mm in 45%~65%. ultrafine Mill belongs to ultra-fine grinding equipment, the grinding fineness reaches 2μm or below. Common grinding machines cannot meet these requirements. ultrafine mill has the features of stable performance, easy to operate, lower energy consumption, wide adjustment range of product granularity, so it's often used to grind non-metallic with medium hardness.
