step749
    4
  • Wohnort
    Catania
  • Homepage
Aktivieren
  1. Hello, my smart is of 2002 year and it has a ZEE.
  2. Hello, I am Italian and I have a smart 450. In the last days I have your same problem. When you run with the smart over 3.500/4000 rpm , the trust plus light come on and the throttle does not respond. I must turn off and then then on the car to run again. I cheked errore with a Mbstar diag and it tells me error 46 or P2046 "Load faluire in monitoring module". I checked all the suction system parts and replaced all! The turbo ,all hoses, all sensores on the engine but the problem persist. Can I have your help? Thanks a lot
  3. Quote: Am 21.06.2017 um 17:29 Uhr hat haibikeqrc geschrieben: Bubissmart scheint ja nicht mehr hier im Forum aktiv zu sein. Hat sonst jemand Ahnung wie das hier beschriebene Problem gelöst werden kann ?????
  4. Hello, I am Italian and I have a smart 450. In the last days I have your same problem. When you run with the smart over 3.500/4000 rpm , the trust plus light come on and the throttle does not respond. I must turn off and then then on the car to run again. I cheked errore with a Mbstar diag and it tells me error 46 or P2046 "Load faluire in monitoring module". I checked all the suction system parts and replaced all! The turbo ,all hoses, all sensores on the engine but the problem persist. Can I have your help? Thanks a lot [ Diese Nachricht wurde editiert von step749 am 22.10.2017 um 17:01 Uhr ]
