mottofreee
Probleme mit der Servobremse
This morning I left the Smart perfectly functional and this evening, after driving 100m, the brake pedal became stiff, I was left without power brake.
The car brakes but the pedal is very difficult to operate. I also felt a bit of ABS when I braked hard. For now I have concluded that the servo part is not working - tomorrow at the light I will check the vacuum pump and the vacuum pipe. I will also put MB Star on and see what it says.
Smart 450 CDI/2005
Sounds like a broken break booster. To check the device, press the brake pedal when the engine isnt running, keep the pressure and start the engine. If the break booster is functional, the pedal will yield a little. If not its likely that there is an issue with the booster unit.
vor 5 Stunden schrieb mottofreee:
this is the correct way, in most cases of missing booster support you will find the cause here. a defect at the booster itself is rare. but may also happen after these years.
Alles wird gut!
Howup , das war das erste, was ich versucht habe, wenn es geknackt hat.
Es knackt überhaupt nicht.
dieselboy , wenn ich die MB Star Diagnose durchführe, werde ich die Servomembran überprüfen.
MB Star a spus că totul este în regulă.
Am găsit ambreiajul pompei de vid rupt.
Problema rezolvata, lipsa vidului.
Acum voi înlocui piesa și lichidul de frână.
974330479_WhatsAppImage2022-11-12at17_32_31.thumb.jpeg.b15a747c85e57870ac41ab8348dc7c05.jpeg
1323681853_WhatsAppImage2022-11-12at08_15_50.thumb.jpeg.35c0054bd3f0b542fa0860b74ea37c4e.jpeg
bearbeitet von mottofreee
vor 23 Stunden schrieb mottofreee:
Was?
Warum lässt Du das eigentlich nachträglich noch mal durch einen Übersetzer laufen, damit es keiner mehr versteht?
Das war gestern noch auf deutsch da gestanden, dessen bin ich mir ganz sicher!
Deshalb konnte ich es gestern im Gegensatz zu heute lesen und verstehen!
Am 12.11.2022 um 16:42 schrieb mottofreee:
Problema rezolvata
Steht doch alles da! Ventil Schlauch abgebrochen, Problem gelöst!😁
Mein Rumänisch hinkt zwar ziemlich aber lesen geht gerade so.
Das ist schon klar, aber gestern war das alles komplett in Deutsch da gestanden! 🤔
Entschuldigung. Ich musste die verbleibende Sprache überprüfen, in Zukunft werde ich mehr darauf achten, was übrig bleibt.
Jetzt habe ich meine Nachricht noch einmal gelesen, sie ist mit diakritischen Zeichen geschrieben und ich schreibe nicht mit diakritischen Zeichen, also wurde meine Nachricht von jemandem oder etwas bearbeitet.
Meine Botschaft lautet:
MB Star sagte, es sei alles in Ordnung.
Ich habe festgestellt, dass die Vakuumpumpenkupplung defekt ist.
Problem gelöst, Mangel an Vakuum.
Ich werde jetzt das Teil und die Bremsflüssigkeit ersetzen.
Die meisten Rumänen, die Ihnen Ärger machen, sind eigentlich Zigeuner aus Rumänien. Und hier, in ihrem Heimatland, machen sie diese Probleme.
Also korrekt heißt das kaputte Teil Rückschlagventil, und die Frage ist, wer das abgebrochen hat, denn von alleine passiert das nicht. Und klar kann die StarDiagnose das nicht erkennen, da der alte Smart noch keinen Vakuumsensor hatte.
Die Bremsflüssigkeit hat mit dem Bauteil so viel zu schaffen wie das Motoröl oder das Scheibenwischwasser.
Ich lese aber raus, daran sind rumänische Zigeuner schuld, die auch in deutsch verfaßte Beiträge in diakritische Zeichen übersetzen. Solche Schufte aber auch.
Zu guter Letzt eine philosophische Fragestellung, die uns in der Bremsentechnik hier schon lange beschäftigt: Kann es einen Mangel an Vakuum überhaupt geben? Oder wäre das dann automatisch ein Zuviel an solchem?
Damit eine gute Nacht an alle.
bearbeitet von dieselbub
Alles wird gut!
vor 3 Stunden schrieb dieselbub:
Je mehr Löcher, desto mehr Käse, je mehr Löcher, desto weniger Käse, je mehr Käse, desto weniger Käse".😁
vor 8 Stunden schrieb Outliner:
Hast du da nicht den Ansatz falsch 🤔 ?
Lautet es nicht vielmehr:
  • Je mehr Käse -> desto mehr Löcher
  • Je mehr Löcher -> desto weniger Käse
  • Schlussfolgerung: Je mehr Käse -> desto weniger Käse 🤪
Hebt Euch das mal gut auf. Wenn wir mal eines Tages skynet lahmlegen müssen, dann mit sowas 😆
Alles wird gut!
...dafür gibt es Tic-Tac-Toe (nicht die Mädchen mit der Scheiße)!
Die Allegorie oben ist die Art, wie die "Grünen" hier in Hamburg für eine stadtweite Tempo 30 Regelung argumentieren. 🤮
dieselboy
1. Der Motor hat es kaputt gemacht . Dort ist er der Einzige, der fähig ist .
2. Die Idee ist, dass die Probleme, die Sie mit Zigeunern haben, auch in Rumänien liegen.
Ein Sprichwort sagt, dass der Wolf seine Haare ändert, aber nicht sein Temperament!
Dem automatischen Übersetzer fehlt es an Intelligenz und ich, ein Sprecher einer anderen Sprache, verstehe Ihr Wortspiel nicht.
Wegen Skynet mache ich mir wenig Sorgen: Da klingelt in Deutschland ein Faxgerät, spuckt ein Stück Papier aus welches abheftet wird. Nix mit Weltherrschaft!
schreibst du eigentlich gags für die heute show oder den böhmermann? das zeug dazu hättest du allemal 😜
Alles wird gut!
    • Es sind eigentlich zwei Räder, nur sind die so eng zusammen, daß die Sonderregelung greift. 🙂 Siehe auch diese Seite!   Außerdem hat der CDIler recht, das ist kein Mopedauto im klassischen Sinn, für das ein kleines Versicherungskennzeichen ausreichend ist! Er darf lediglich bereits ab 16 Jahren mit dem entsprechenden Führerschein gefahren werden! 😉
