czy
verbrauch computer fur Cdi
Is it possible to installe an on board computer for the Smart Cdi so I can monitor my fuel consumption on board.
Thanks
Czy
No Way...
but you can use a PC at Home.
Enter wath you fill in the Tank and the Km you have drive. Then you can get wath he takes.
Look at the Downloads here, there are some Examples for MS-Works and MS-Exel.
Clever und Smart Cabrio CDI !
By Oeffi
By Oeffi
Hello czy,
if you have a handheld with PalmOS, you can use a simple Program called Automobil. You can find it here. But it´s a German Version. This program is Shareware but there is no restriction, only a popup-Window with the Shareware-hint. I use this Program since July 2002 and it operates very good. My cdi takes 3,97Liter per 100km.
I hope, I could help you...
Ist schon lange her, dass ich in Englisch geschrieben habe, daher möge man mir evtl. vorhandene Fehler verzeihen!
www.smart-basteln.de
Gruß, M.
Hey czy,
if it's so important to monitor your cars gas consumption you ought to think about walking or using public transportation. No other affordable car uses so little gas. trust me.
why don't you just zero your trip-counter every time you stop for gas. It should be more than enough to just take the liters you tankt (disregard the coma, use the four didget number) and devide them through the driven km!
Are you trying to do research or do you want to have fun with the little guy?
Rgds
Bobby
Thanks for the answers!!!
I have my Cdi from 12/00 with 67.000 Km and I am trying to keep my consumption as low as possible. The average is 3,5 l/100 Km.
Minimum 2,93 L.
Ciao pé
so einen richtigen verbrauchscomputer, mit momentan verbrauch.. ist sowas in der mache?? Da der Smart ja vollelektronisch ist, sollte das doch auch irgendwo erfast werden oder??
img.cgi?fahrzeug=100428
Am 21.03.2003 um 12:18 Uhr hat Silver-Bullet-Driver geschrieben:
... Da der Smart ja vollelektronisch ist, sollte das doch auch irgendwo erfast werden oder??
wozu???
Die Einspritzmenge wird berechnet und die berechnete Menge eingespritzt.
Gruß aus Frankfurt am Main
Carsten
www.smartronik.com
    • ich hatte vor 2 Jahren die Benzinpumpe (450er 23l. Tank..) gewechselt. Der Tank muß auch auf Reserve sein ...Tank runter lassen ... dann kommt man ja gut ran. Als Werkzeug die Überwurfmutter zu lösen habe ich eine Fahradkette genommen die an eine Zange geschweißt war... War ein selber gemachtes Ölfilter wechsel Tool. Um den Ring gelegt und schwubb war das auf. Den neuen Dichtring habe ich mit Siliconfett eingerieben und die Gewindegänge  vom Ring auch. Aber trotzdem volle kanne zudrehen sonst bleibt das undicht. Mit dem Werkzeug kein Problem. Daran rumkloppen mit dem Hammer würde ich nie. Das Ding kann auch brechen. alle Leitungen und Stecker überprüfen ...rausziehen... Wasserverdrängungspray rein .. alles nachgesehen und wieder Tank angeschraubt. Auf der Hebebühne 2 h arbeit
