Djurhamn
stromlos
If the battery is empty how should i get inside the car ? or to give it starthilfe ?
Thanks for your tip but do you now how to give it power to the batteri from the backdoor
Am 07.11.2007 um 12:55 Uhr hat Djurhamn geschrieben:
Open the Sidedoor! ;-)
You only have to take a long cabel (however the name for "Starterkabel" ist in english) because den batterie is inside under the carpet from the front seat passenger.
second possibility: You can run the engine by bowl first: Key at position "1", gearshift at position "+" an hold at this position...than bowl first an make "kickdown" while doing.
...ich kann doch kein Ausländisch :lol:
* ICQ:142 - 336 - 619 *
Wenn die Stellmotoren zu gezogen haben, dann sind sie zu ;-)
You may try to bump start your smart:
Bump Start the SMART
Then you can open the doors with the remote and charge/replace the battery... ;-)
